I am attempting to setup a simple nodejs application to geocode addresses, which is based on the following blog post
https://www.esri.com/arcgis-blog/products/developers/developers/find-address-coordinates-using-node-js/
In doing so, I went through the process of setting up an account then setting up an ApiKey with my developer account. I also gave it access to the geocoding feature. However in every case, I keep getting an error
ArcGISAuthError: 498: Invalid Token
at checkForErrors (***/test-arcgis/node_modules/@esri/arcgis-rest-request/dist/cjs/request.js:145:23)
at /***/test-arcgis/node_modules/@esri/arcgis-rest-request/dist/cjs/request.js:366:30
at process.processTicksAndRejections (node:internal/process/task_queues:95:5) {
originalMessage: 'Invalid Token',
code: 498,
response: { error: { code: 498, message: 'Invalid Token', details: [] } },
url: 'https://geocode-api.arcgis.com/arcgis/rest/services/World/GeocodeServer/findAddressCandidates',
options: {
httpMethod: 'POST',
params: {
f: 'json',
address: 'N Main st',
postal: 38103,
countryCode: 'USA'
authentication: ApiKeyManager {
portal: 'https://www.arcgis.com/sharing/rest',
key: '***jGmAOVb'
headers: {}
I am not quite sure how to resolve this or determine if I set it up correctly
I have gone through a series of online resources and have not been able to find the correct way to set this up.
Any assistance is appreciated.
Any assistance
