I use the credential-identity Manager in an Anular 18 OAuth Project ( I log myself on into an Enterprise portal). I can't figure out how I could log my testuser in (in the Angular Jasmin and Karma Tests). I can't log my user in because I have a UI -Login Process and it looks like this:
authService:
public async initializeLogin(): Promise<boolean> {
IdentityManager.registerOAuthInfos([oauthInfo]);
try {
this.credential = await IdentityManager.checkSignInStatus(signInUrl);
console.log('user successfully logged in');
this.portal = (await new Portal({ url: oauthInfo.portalUrl }).load()) as Portal;
this.groups = await this.portal.user?.fetchGroups();
// Update credentials after successful login
this._credential$.next(this.credential);
// Initialize the ArcGIS REST API with the user's credentials
this.initArcGisRESTAuthentication();
environment.token = this.credential.token;
return true;
} catch (e) {
console.log('user not logged in', e);
this.login();
return false;
private initArcGisRESTAuthentication() {
const token = Promise.resolve(this.credential.token);
const authentication = {
portal: signInUrl + '/rest',
getToken(): Promise<string> {
return token;
setDefaultRequestOptions({ authentication }, true);
login() {
void IdentityManager.getCredential(signInUrl);
AppComponent:
async ngOnInit() {
await this.authService.initialized;
get userName() {
return this.authService.portal.user.username;
get displayName() {
return this.authService.portal.user.fullName;
get initialized() {
return this.authService.initialized;
logout() {
return this.authService.logout();
The Test of the AppComponent:
import { ComponentFixture, TestBed, waitForAsync } from '@angular/core/testing';
import { By } from '@angular/platform-browser';
import { RouterTestingModule } from '@angular/router/testing';
import { NoopAnimationsModule } from '@angular/platform-browser/animations';
import { SbbIconTestingModule } from '@sbb-esta/angular/icon/testing';
import { SbbMenuItem } from '@sbb-esta/angular/menu';
import { HttpClientModule } from '@angular/common/http';
import { AppComponent } from './app.component';
import { AuthService } from './services/oauth/auth.service';
import { ActivatedRoute } from '@angular/router';
describe('AppComponent', () => {
let component: AppComponent;
let fixture: ComponentFixture<AppComponent>;
let authService: AuthService;
beforeEach(waitForAsync(() => {
TestBed.configureTestingModule({
imports: [
RouterTestingModule,
NoopAnimationsModule,
SbbIconTestingModule,
HttpClientModule,
AppComponent // Standalone-Komponente wird hier importiert
providers: [
AuthService,
provide: ActivatedRoute,
useValue: {
snapshot: {
paramMap: {
get: (key: string) => (key === 'id' ? '123' : null),
}).compileComponents();
beforeEach(() => {
fixture = TestBed.createComponent(AppComponent);
component = fixture.componentInstance;
authService = TestBed.inject(AuthService);
fixture.detectChanges();
it('should create', () => {
expect(component).toBeTruthy();
it('should render title', () => {
expect(fixture.nativeElement.querySelector('.sbb-header-lean-titlebox > span').textContent).toContain('ESTA GIS Blueprint');
it('should render username', waitForAsync(async () => {
await authService.initializeLogin();
expect(fixture.nativeElement.querySelector('.sbb-usermenu-user-info-display-name').textContent).toContain(authService.portal.user.fullName);
it('should logout', waitForAsync(async () => {
const logoutSpy = spyOn(authService, 'logout').and.callThrough();
const usermenuOpenButton = fixture.debugElement.query(By.css('.sbb-menu-trigger-usermenu'));
usermenuOpenButton.nativeElement.click();
const logoutButton = fixture.debugElement.query(By.directive(SbbMenuItem));
logoutButton.nativeElement.click();
expect(logoutSpy).toHaveBeenCalled();
it('should login successfully', waitForAsync(async () => {
await component.ngOnInit();
expect(authService.authenticated).toBeTrue();
expect(component.initialized).toBeTrue();
it('should fail to login and not proceed with tests', waitForAsync(async () => {
spyOn(authService, 'initializeLogin').and.throwError('Login failed');
expect(authService.authenticated).toBeFalse();
expect(component.initialized).toBeFalsy();
I can't say my authService with which user he should log in...
