Hi - I've been invited to work on a project in which I've been identified as the wetlands specialist. This is an optimisitic title but a good opportunity to learn. I've started investigating ArcHydro and will hopefully use it to identify aeas of our case study catchment suitable for wetland restoration, and then to quantify what impact they might have on flood mitigation.
I hope someone can answer a couple of beginner questions.
1) folder set up. I've read the Arc Hydro best practice notes, just not sure if I'm setting up the separate folders for each run I want to do in the most efficient way. In the Arc Hydro Dendric Stream Unknown Terrain tool (where I'm starting, as per the online videos), I'm going through each box and pointing the tool to a new folder I've created on my harddrive for each run. Screenshot attached. This is quite labourious - is there a quicker way?
2) Point Delineator tool - again, I'm next looking at this tool because the intro online tutorial moves to this one. Its giving me an error after i use the pencil to identify a point. Note I have pointed the Inputs to the tifs I've just created in 1) above, but for for Input Adjoint Catchment Feature Class I wasn't sure, so selected the case study boundary feature. I'm getting this star icon when I select the pencil to input the points, which doesn't match the red point in the tutorial. Screenshot attached. Any guidance much appreciated.
Thanks for any help. I'm sure there'll be more.
Richard
