Enable Network Topology
Parameters
Input Utility Network C:\Users\ycamacho\OneDrive - Geotecnologias S.A\Documentos\ArcGIS\Projects\Prueba\SQLServer-crgis36-pruebas_trelec(utility).sde\pruebas_trelec.UTILITY.Electric\pruebas_trelec.UTILITY.UtilityNetworkEPM
Maximum number of errors 10000
Only generate errors ENABLE_TOPO
Updated Utility Network C:\Users\ycamacho\OneDrive - Geotecnologias S.A\Documentos\ArcGIS\Projects\Prueba\SQLServer-crgis36-pruebas_trelec(utility).sde\pruebas_trelec.UTILITY.Electric\pruebas_trelec.UTILITY.UtilityNetworkEPM
Messages
Hi. Is there a standard solution for this error? I alredy install all the updates for Windows and restart the server
Start Time: jueves, 29 de agosto de 2024 08:35:25
ERROR 999999: Something unexpected caused the tool to fail. Contact Esri Technical Support (http://esriurl.com/support) to Report a Bug, and refer to the error help for potential solutions or workarounds.
FDO error: -2147195905 [Error querying row from table pruebas_trelec.UTILITY.ElectricJunction]
Table schema changed after cursor declared [42000:[Microsoft][ODBC Driver 17 for SQL Server][SQL Server]Could not complete cursor operation because the table schema changed after the cursor was declared.] [pruebas_trelec.UTILITY.ElectricJunction][STATE_ID = 0]
Table schema changed after cursor declared [42000:[Microsoft][ODBC Driver 17 for SQL Server][SQL Server]Could not complete cursor operation because the table schema changed after the cursor was declared.] [pruebas_trelec.UTILITY.UN_6_DirtyAreas][STATE_ID = 0]
