Hi, my team has been having an issue where data is being sent from a survey, and the resulting AGOL dataset is missing data from several fields. The fields that are missing the data are reasonably consistent (as in there are a couple of fields where this occurs, but most of the attributes are being written as expected), but there is no consistency with the circumstances in which this happens (as in an identical record could be created with no issues). One of the fields is a calculated field, but it is definitely calculating correctly.
The team is collecting hundreds of such surveys with potentially 50+ repeats per survey (and the missing data is in the repeats), usually completed in offline mode, and the missing data is often not identified until it's too late - the sent box is being wiped.
I have replicated an example of this behaviour, where the data from one of the repeats is partially missing once the survey is sent. I was able to copy the sent data to a new survey and resubmit the survey unchanged, and the missing information was available, and correctly sent, in the new survey.
Any advice would be appreciated,
Thanks, Felicity
