I have 3D data representing measured soil parameters, and when I performed EBK 3D in ArcGIS Pro, the predicted values maintained the correct range, with the minimum and maximum values consistent with my original data.
However, when I export the results to a voxel layer and then import them as a Geostatistical Analyst (GA) layer to create sections and better visualize the model, I notice that the range of the data becomes narrower. Both the minimum and maximum values are lower than those in the original dataset.
I’m concerned that the interpolation process might be altering the true values of the observed data instead of preserving them exactly as they are. This is particularly important in my case, as it's crucial that the original data values are retained at the known locations.
Could someone explain how this process works and why these changes might be occurring?
Best,
