In 3.X, this was quite simple as there was the infoWindow.Resize() method but there seemingly is not an equivalent option in 4.X? The closest thing I found was this thread where someone was using CSS to resize the popup. Unfortunately, this hasn't been working for me and I need to adjust the popup's dimensions a number of times, depending on the layer that was clicked.
In my attempt, I'm using reactiveUtil to watch for features being added to the popup:
reactiveUtils.watch(()=>theView.popup.features, (event)=>{
// If the zoom-out action is clicked, fire the zoomOut() function
//Attempt to resize the popup based on the layer
if (event.length > 0) {
var theLayerName = theView.popup.features[0].layer.id;
switch(theLayerName) {
case "tipLine":
break;
case "tipPoint":
break;
case "swmCip":
break;
case "schools":
break;
case "parcels":
break;
case "raceTracts":
app.plmf.resizePopupWindow(925,500);
break;
case "raceBlockGroups":
break;
case "povertyTracts":
break;
case "povertyBlockGroups":
break;
case "lepTracts":
break;
case "lepBlockGroups":
break;
case "ageSexTracts":
break;
case "ageSexBlockGroups":
break;
case "disabilityTracts":
break;
case "disabilityBlockGroups":
break;
case "originTracts":
break;
default:
And then the function that is called to attempt to resize the popup is as follows:
resizePopupWindow(theWidth,theHeight) {
var theCssWidth = theWidth + 'px !important';
var theCssHeight = theHeight + 'px !important';
var cols = document.querySelectorAll('.esri-view-width-xlarge .esri-popup__main-container, .esri-view-width-large .esri-popup__main-container, .esri-view-width-medium .esri-popup__main-container');
if (cols.length > 0) {
for(var i = 0; i < cols.length; i++) {
cols[i].style.height = theCssHeight;
cols[i].style.width = theCssWidth;
