I created an Experience with the ArcGIS Experience Builder Developer version, which is deployed on my server. Since I want users to use Analysis tools I have included in the Experience I need to implement user authentication. I want users to have a login button to then be able to view the map and use the tools in my experience.
I don't have much experience with authentication processes so I have not been able to include the authentication process properly into my Experience. So far I have come up with the following code:
<!doctype html>
<html lang="en-us">
<head>
<meta name="viewport" content="width=device-width,initial-scale=1,user-scalable=no"/>
<meta http-equiv="X-UA-Compatible" content="IE=EDGE"/>
<meta name="google-site-verification" content="Gl928UcZRBt8t7njrpXivrsVrbVcc7sLybtCMZ6Dzlg"/>
<title>Web GIS</title>
<link rel="shortcut icon" href="assets/exb.ico">
<link rel="stylesheet" href="https://js.arcgis.com/4.29/esri/themes/light/main.css">
<base href="./cdn/4/"/>
<script src="https://cdn.jsdelivr.net/npm/bowser@2.11.0/es5.js"></script>
<style>
scrollbar-color: var(--light-600) transparent;
html, body {
width: 100%;
height: 100%;
margin: 0;
overflow: hidden;
html.scrollable {
overflow: auto;
html.scrollable body {
overflow: unset;
html.scrollable body, html.scrollable #app {
height: auto;
#loading {
width: 100vw;
height: 100vh;
#app {
width: 100%;
height: 100%;
position: relative;
z-index: 0;
display: none;
.auth-buttons {
position: absolute;
top: 10px;
right: 10px;
z-index: 10;
.auth-buttons button {
margin-left: 10px;
</style>
</head>
<body>
<div id="loading">
<style>
.loading-content {
position: absolute;
top: 0;
bottom: 0;
left: 0;
right: 0;
.jimu-primary-loading-app:before, .jimu-primary-loading-app:after {
position: absolute;
top: 0;
content: '';
.jimu-primary-loading-app:before {
left: -19.992px;
left: 19.992px;
-webkit-animation-delay: 0.32s !important;
.jimu-primary-loading-app:before, .jimu-primary-loading-app:after, .jimu-primary-loading-app {
background: #076fe5;
-webkit-animation: loading-keys-app-loading 0.8s infinite ease-in-out;
width: 13.6px;
height: 32px;
text-indent: -9999em;
margin: auto;
position: absolute;
right: calc(50% - 6.8px);
top: calc(50% - 16px);
-webkit-animation-delay: 0.16s !important;
@-webkit-keyframes loading-keys-app-loading {
0%, 80%, 100% { opacity: .75; box-shadow: 0 0 #076fe5; height: 32px; }
40% { opacity: 1; box-shadow: 0 -8px #076fe5; height: 40px; }
@keyframes loading-keys-app-loading {
</style>
<div class="loading-content">
<div class="justify-content-center jimu-primary-loading-app"></div>
</div>
</div>
<div id="app"></div>
<div class="auth-buttons">
<button id="sign-in" class="btn btn-primary">Sign In</button>
<button id="sign-out" class="btn btn-primary" style="display:none;">Sign Out</button>
</div>
<pre><code id="results"></code></pre>
<script type="webpack-options" id="webpack-options">{
"mountPath": "/",
"isOutOfExb": true,
"hostEnv": "prod",
"appFolderName": ".",
"useStructuralUrl": false,
"arcgisJsApiUrl": "https://js.arcgis.com/4.29/",
"isDevEdition": true,
"buildNumber": "1",
"isBuilder": false,
"isSite": false,
"isInPortal": false
}</script>
<script type="systemjs-importmap">{
"imports": {
"jimu-core": "https://BASE_URL/jimu-core/index.js",
"jimu-core/": "https://BASE_URL/jimu-core/",
"jimu-theme": "https://BASE_URL/jimu-theme/index.js",
"jimu-theme/": "https://BASE_URL/jimu-theme/",
"jimu-ui": "https://BASE_URL/jimu-ui/index.js",
"jimu-ui/": "https://BASE_URL/jimu-ui/",
"jimu-icons/": "https://BASE_URL/jimu-icons/",
"jimu-arcgis": "https://BASE_URL/jimu-arcgis/index.js",
"jimu-arcgis/": "https://BASE_URL/jimu-arcgis/",
"jimu-layouts": "https://BASE_URL/jimu-layouts/index.js",
"jimu-layouts/": "https://BASE_URL/jimu-layouts/",
"jimu-for-builder": "https://BASE_URL/jimu-for-builder/index.js",
"jimu-for-builder/": "https://BASE_URL/jimu-for-builder/",
"widgets/": "https://BASE_URL/widgets/",
"themes/": "https://BASE_URL/themes/",
"builder/": "https://BASE_URL/builder/",
"site/": "https://BASE_URL/site/",
"experience/": "https://BASE_URL/experience/",
"template/": "https://BASE_URL/template/",
"templates/": "https://BASE_URL/templates/",
"calcite-components": "https://BASE_URL/calcite-components/index.js",
"calcite-components/": "https://BASE_URL/calcite-components/",
"arcgis-charts": "https://BASE_URL/arcgis-charts/arcgis-charts.js",
"arcgis-amd-packages/": "https://amd-packages/",
"esri/": "https://API_URL/esri/"
}</script>
<script src="./jimu-core/init.js"></script>
<!-- Authentication script -->
<script>
require([
"esri/portal/Portal",
"esri/identity/OAuthInfo",
"esri/identity/IdentityManager"
], function (Portal, OAuthInfo, esriId) {
const info = new OAuthInfo({
appId: "My-APP-ID", // removed due to privacy reasons
popup: false // Use false if you want to redirect instead of using a popup
esriId.registerOAuthInfos([info]);
esriId.checkSignInStatus(info.portalUrl + "/sharing")
.then(() => {
handleSignedIn();
.catch(() => {
handleSignedOut();
document.getElementById("sign-in").addEventListener("click", function () {
esriId.getCredential(info.portalUrl + "/sharing");
document.getElementById("sign-out").addEventListener("click", function () {
esriId.destroyCredentials();
window.location.reload();
function handleSignedIn() {
const portal = new Portal();
portal.load().then(() => {
const results = {
username: portal.user.username
document.getElementById("results").innerText = JSON.stringify(results, null, 2);
document.getElementById("sign-in").style.display = "none";
document.getElementById("sign-out").style.display = "block";
function handleSignedOut() {
document.getElementById("results").innerText = 'Signed Out';
document.getElementById("sign-in").style.display = "block";
document.getElementById("sign-out").style.display = "none";
</script>
</body>
</html>
This will load my Experience and display a button, but I can't log in due to a ReferenceError: require is not defined. Adding <script src="https://js.arcgis.com/4.29/"></script> in the header will result in a MultipleDefines Error instead.
Any help would be appreciated.
