Is it possible to have multiple filter widgets that act simultaneously on the same layer (and in fact the same variable in the same layer)? Basically I have several different groups of options, which I want to be able to display as separate groups with some text explaining them (hence separate filter widgets) but allow the user to mix and match options from both within and among the groups. I started out with two separate filter widgets to see if it would work and nothing in the layer is showing (even though some of the filters are set to be on at startup). I’m just wondering is nothing showing up because it is not possible to have multiple filter widgets acting on one layer or if it is my user error and I need to change an option somewhere.
if the multiple filter widgets is not possible, does anyone have an idea for an alternative way to do what I want to do? Thank you!
