Using AGO & latest version of Field Maps.
Field Maps does not honor multiple label classes.
- Labels are enabled at the HFL level (using Visualization Tab).
- Modification to the labels within the web map are saved and honored in both Map Viewer and Field Maps mobile app
- Adding a second label class to the layer within the web map only Map Viewer displays the label class correctly; Field Map mobile app only displays the first label class.
Use case:
Map Viewer does not support symbolizing by multiple fields in the case of say Type + Status fields/two text fields. [Map Viewer only supports multiple fields in the sense of choose a field, then choose another to define symbology graduation.]
Map Viewer does not support Arcade driven symbology based on conditional logic.
The workaround here was to create a secondary label class to indicate the status of a point feature while the symbology indicated the 'type' of the feature.
Has anyone else tried to use multiple label classes in Field Maps? I cannot find any documentation regarding this.
