Hi All,
I'm transitioning from ArcMap to ArcPro. I used to use the HEC-GeoRAS toolbar to convert GIS data extracted from a HEC-RAS model into a geodatabase for floodplain delineation. Unfortunately, the toolbar is not supported in Pro. However, I saw that the ArcHydro tools have a similar process to convert the SDF file extracted from HEC-RAS into a geodatabase.
Unfortunately, I've experienced wildly inconsistent results with this tool. For example, I was able to sucessfully import all features (XS, River2D, BoundingPolygon, etc.) once for a relatively simple model (one waterline, 47 XS). I also tried to import data from two more complex models (many waterlines and reaches, several hundred to several thousand XS). One attempt at importing only resulted in XS for one reach and a waterline for a different reach (and many error messsages). Another attempt resulted in only one reach for one waterline but all of the XS for all reaches.
I am using ArcPro 3.3.1, the ArcHydro tools for version 3.2.7 (from here: https://downloads.esri.com/archydro/archydro/Setup/Pro/3.2/) and HEC-RAS versions 6.0.0 and 6.3. Any thoughts?
Curtis Abert
Illinois State Water Survey / Prairie Research Insitute / University of Illinois
