In Field Maps, I realize that you can set a precision constraint in the mobile app based on the external device.
But I'm wondering if it's possible to only show some questions/fields based on metadata from the connected device?
For example, I would wish to make visible a certain question based on the fix type or even the correction age. I tried setting a simple arcade expression to the the visible parameter in my form ($feature.esrignss_correctionage < 2), but it doesn't seem to work and what I'm thinking is that this is normal because the field is not populated yet.
How does one get the GPS metadata on the fly with arcade?
Thanks!
