Geojson data. I must admit, it is one of the weirdest standard data formats that I have come across. But, they are out there and you adapt.
Begin with getting the keys of a nested dictionary.
def get_keys(data, num):
"""Return dictiony keys by level.
Parameters
data : dictionary in geojson format
num : beginning index number
Useage
r = get_keys(data, 0)
keys = []
if isinstance(data, dict):
num += 1
for key, value in data.items():
t = type(value).__name__
keys.append((num, key, t))
keys += get_keys(value, num)
elif isinstance(data, list):
for value in data[:1]:
# num += 1
return keysAn example of a simple geojson with 3 shapes, a couple of them multipolygons and some attributes (which I don't actually carry about, but they were there).
In this example, I returned the level, name and data type. A quick modification to the above and you could return the values/items.
get_keys(vals, 0)
[(1, 'type', 'str'),
(1, 'crs', 'dict'),
(2, 'type', 'str'),
(2, 'properties', 'dict'),
(3, 'name', 'str'),
(1, 'features', 'list'),
(2, 'type', 'str'),
(2, 'id', 'int'),
(2, 'geometry', 'dict'),
(3, 'type', 'str'),
(3, 'coordinates', 'list'),
(3, 'OBJECTID', 'int'),
(3, 'Parts', 'int'),
(3, 'Points', 'int'),
(3, 'Curves', 'int'),
(3, 'A0', 'str'),
(3, 'A1', 'str'),
(3, 'Longs_', 'int'),
(3, 'Area_perim', 'float'),
(3, 'srt_a0a1', 'int'),
(3, 'Int_nulls', 'int'),
(3, 'Float_nulls', 'NoneType'),
(3, 'Text_nulls', 'str'),
(3, 'OID_', 'int'),
(3, 'Dbls_', 'int'),
(3, 'Shape_Length', 'float'),
(3, 'Shape_Area', 'float')]
Not bad, but one of the 1's is out of the expected order, so on to the next incarnation...printing to show the nested levels of the keys.
prn_keys(vals, 0)
1 type str
1 crs dict
2 type str
2 properties dict
3 name str
1 features list
2 type str
2 id int
2 geometry dict
3 type str
3 coordinates list
2 properties dict
3 OBJECTID int
3 Parts int
3 Points int
3 Curves int
3 A0 str
3 A1 str
3 Longs_ int
3 Area_perim float
3 srt_a0a1 int
3 Int_nulls int
3 Float_nulls NoneType
3 Text_nulls str
3 OID_ int
3 Dbls_ int
3 Shape_Length float
3 Shape_Area float You can use numpy to pull out information from the key data
kys = get_keys(vals, 0)
dt = np.dtype([('Level', 'i4'), ('Key_name', 'U15'), ('Type', 'U10')])
val_arr = np.asarray(kys, dtype=dt)
# -- do a little query, pull out the results, and show as a list
q = val_arr['Level'] == 1 # query, get all level 1 keys
result = val_arr[q]
result.tolist()
(1, 'crs', 'dict'),
(1, 'features', 'list')]If you want to load a geojson and mess with the data structure yourself, here is a script
def load_geojson(pth, full=True, just_geometry=False):
"""Load a geojson file and convert to a Geo Array.
The geojson is from the ``Features to JSON`` tool listed in the references.
Parameters
pth : file path
Full file path to the geojson file.
full : boolean
True to return a formatted geojson file.
geometry : boolean
True returns just the geometry of the file.
Returns
data : dictionary
The full geojson dictionary of the geometry and its attributes. The
result is a nested dictionary::
>>> data
... {'type': # first feature
... 'crs': {'type': 'name', 'properties': {'name': 'EPSG:2951'}},
... 'features':
... [{'type': 'Feature',
... 'id': 1,
... 'geometry': {'type': 'MultiPolygon',
... 'coordinates': snip}, # coordinate values
... 'properties': snip }}, # attribute values from table
... {'type': # next feature
... ... repeat}
geometry : list
A list of lists representing the features, their parts (for multipart
features) and inner holes (for polygons).
Notes
Using the Features to JSON tool in ArcGIS PRO, the .json option was used.
- Unchecked : The output will be created as Esri JSON (.json).
- Checked : The output will be created in the GeoJSON format (.geojson).
References
`geojson specification in detail
<https://geojson.org/>`_.
`Wikipedia link
<https://en.wikipedia.org/wiki/GeoJSON>`_.
`Features to JSON
<https://pro.arcgis.com/en/pro-app/tool-reference/conversion/
features-to-json.htm>`_.
`JSON to Features
json-to-features.htm>`_.
# import json # required if run outside
with open(pth) as f:
data = json.load(f)
type_key = pth.split(".")[-1]
keys = list(data.keys())
if 'features' in keys:
shapes = data['features']
coord_key = ['rings', 'coordinates'][type_key == 'geojson']
coords = [s['geometry'][coord_key] for s in shapes] # 'rings'
if full and just_geometry:
print("\nReturning full geojson and just the geometry portion")
print("as a list")
return data, coords
if full:
return data
if just_geometry:
return coordsIf you are interested in alternate geometry construct, see and example on my github site (geo arrays)
NumPy Geometry (npg geometry arrays)
Enjoy
