Does anyone else have issues with having both of these installed on the same server. I had ArcGIS 10.2.1. for Desktop installed and had been running many python scripts for some geoprocessing. All geoprocessors were working without issues until I installed ArcGIS 10.2.1 for Server. Now all of the geoprocessors that were running prior no longer work. Is there something I need to modify in the python scripts to allow them to function on a server with both of these installed?
For example I have a python script that drops fields from many feature classes (arcpy.DeleteField_management). When I run it from my server with both installed it fails with the following.
"Failed to execute. Parameters are not valid.
ERROR 000732: Input Table: "TableName" does not exist or is not supported."
If I copy the python script and sde data connection file to another server with only ArcGIS 10.2.1 for Desktop installed it works without issue. I also have another python script that uses the following:
fcList = arcpy.ListFeatureClasses()
for fc in fcList:
It throws the error:
TypeError: 'Nonetype' object is not iterable.
Again though I can copy the sde connection file and python to another server with only ArcGIS 10.2.1 for Desktop installed and everything works properly. I have also replicated the python failures on another server that has both installed.
