using ArcGIS.Core.CIM;
using ArcGIS.Core.Data;
using ArcGIS.Core.Events;
using ArcGIS.Core.Geometry;
using ArcGIS.Core.Internal.Geometry;
using ArcGIS.Desktop.Editing;
using ArcGIS.Desktop.Editing.Events;
using ArcGIS.Desktop.Framework.Contracts;
using ArcGIS.Desktop.Framework.Threading.Tasks;
using ArcGIS.Desktop.Mapping;
using System;
using System.Collections.Generic;
using System.Linq;
using System.Threading.Tasks;
namespace muffe_add_in
internal class Button1 : Button
private SubscriptionToken _rowCreatedEventToken;
private SubscriptionToken _rowChangedEventToken;
private SubscriptionToken _rowDeletedEventToken; // New token for RowDeletedEvent
private bool _isActive = false; // Field to track the active state
private Dictionary<long, Geometry> _originalGeometries = new Dictionary<long, Geometry>();
protected override void OnClick()
_isActive = !_isActive; // Toggle the active state
if (_isActive)
// Ensure the subscription logic is awaited properly
QueuedTask.Run(async () =>
try
// Assuming you have a way to access or select the feature layer you're working with
var featureLayer = MapView.Active.Map.GetLayersAsFlattenedList().OfType<FeatureLayer>().FirstOrDefault(l => l.Name == "Plan Kabler");
if (featureLayer != null)
// Correctly obtain the spatial reference from the feature layer's dataset
var spatialReference = await QueuedTask.Run(() => featureLayer.GetFeatureClass().GetDefinition().GetSpatialReference());
_rowCreatedEventToken = RowCreatedEvent.Subscribe((args) => OnRowCreatedOrEdited(args, true), featureLayer.GetTable(), false);
_rowChangedEventToken = RowChangedEvent.Subscribe((args) => OnRowCreatedOrEdited(args, false), featureLayer.GetTable(), false);
_rowDeletedEventToken = RowDeletedEvent.Subscribe(OnRowDeleted, featureLayer.GetTable(), false); // Subscribe to RowDeletedEvent
catch (Exception ex)
// Log the exception to the ArcGIS Pro log or show a message box
System.Diagnostics.Debug.WriteLine($"Error subscribing to events: {ex.Message}");
}).Wait();
UpdateCaption("Deactivate Muffe");
else
// Unsubscribe logic should also be within QueuedTask.Run if it interacts with ArcGIS objects
RowCreatedEvent.Unsubscribe(_rowCreatedEventToken);
RowChangedEvent.Unsubscribe(_rowChangedEventToken);
RowDeletedEvent.Unsubscribe(_rowDeletedEventToken); // Unsubscribe from RowDeletedEvent
_rowCreatedEventToken = null;
_rowChangedEventToken = null;
_rowDeletedEventToken = null;
}).Wait();
UpdateCaption("Activate Muffe");
private void UpdateCaption(string newCaption)
// Directly update the caption since this method is called within QueuedTask.Run
this.Caption = newCaption;
private async void OnRowCreatedOrEdited(RowChangedEventArgs args, bool isInsert)
if (!_isActive) return; // Check if the script is active before proceeding
if (!(args.Row is Feature feature)) return;
if (feature.GetTable().GetName() != "Plan_Kabler") return;
var featureId = feature.GetObjectID();
var polyline = feature.GetShape() as Polyline;
if (polyline == null) return;
// If there is an existing geometry, delete it
if (_originalGeometries.ContainsKey(featureId))
await QueuedTask.Run(async () =>
var muffePunktLayer = MapView.Active.Map.GetLayersAsFlattenedList().OfType<FeatureLayer>().FirstOrDefault(l => l.Name == "Muffe Punkt");
var muffeArealLayer = MapView.Active.Map.GetLayersAsFlattenedList().OfType<FeatureLayer>().FirstOrDefault(l => l.Name == "Muffe Areal");
if (muffePunktLayer == null || muffeArealLayer == null) return;
// Delete intersecting templates
await DeleteIntersectingTemplates(featureId, muffePunktLayer, muffeArealLayer);
// Remove the old geometry from the dictionary
_originalGeometries.Remove(featureId);
// Store the new geometry
_originalGeometries[featureId] = polyline.Clone();
if (isInsert)
// Logic for handling row insertions
await ApplyTemplateAlongPolyline(polyline, muffePunktLayer, muffeArealLayer);
else
// Logic for handling row updates
private async void OnRowDeleted(RowChangedEventArgs args)
// Logic for handling row deletions
private async Task ApplyTemplateAlongPolyline(Polyline polyline, FeatureLayer muffePunktLayer, FeatureLayer muffeArealLayer)
// Ensure spatial reference is correctly obtained
var spatialReference = await QueuedTask.Run(() => muffeArealLayer.GetFeatureClass().GetDefinition().GetSpatialReference());
double interval = 100.0; // Interval in meters
double distanceToNextPoint = 0; // Start with 0 to place the first point immediately
foreach (var part in polyline.Parts)
double distanceCoveredInSegment = 0.0;
foreach (var segment in part)
double segmentLength = CalculateSegmentLength(segment);
while (distanceCoveredInSegment + distanceToNextPoint <= segmentLength)
double proportion = distanceToNextPoint / segmentLength;
MapPoint position = CalculatePositionAlongSegment(segment, proportion + (distanceCoveredInSegment / segmentLength));
double angle = CalculateSegmentAngle(segment);
try
// Attempt to create and place the point and polygons at this position
await CreateAndPlacePolygons(position, angle, spatialReference, muffeArealLayer);
await CreateFeatureInLayer(muffePunktLayer, position);
// Log or handle the error
Console.WriteLine($"Failed to create feature: {ex.Message}");
distanceCoveredInSegment += distanceToNextPoint;
distanceToNextPoint = interval; // Reset after placing a point
distanceToNextPoint -= (segmentLength - distanceCoveredInSegment);
private double CalculateSegmentLength(Segment segment)
return Math.Sqrt(Math.Pow(segment.EndPoint.X - segment.StartPoint.X, 2) + Math.Pow(segment.EndPoint.Y - segment.StartPoint.Y, 2));
private MapPoint CalculatePositionAlongSegment(Segment segment, double proportion)
double x = segment.StartPoint.X + (segment.EndPoint.X - segment.StartPoint.X) * proportion;
double y = segment.StartPoint.Y + (segment.EndPoint.Y - segment.StartPoint.Y) * proportion;
return MapPointBuilder.CreateMapPoint(x, y, segment.SpatialReference);
private double CalculateSegmentAngle(Segment segment)
double dx = segment.EndPoint.X - segment.StartPoint.X;
double dy = segment.EndPoint.Y - segment.StartPoint.Y;
return Math.Atan2(dy, dx) * (180 / Math.PI); // Angle in degrees
private async Task CreateAndPlacePolygons(MapPoint position, double angle, SpatialReference spatialReference, FeatureLayer layer)
// Adjust the offset distances for left and right polygons
double offsetDistanceLeft = 5; // Offset distance for left polygons
double offsetDistanceRight = 10; // Offset distance for right polygons
// Calculate perpendicular direction for left and right offsets
double angleLeft = angle - 90; // Perpendicular to the left
double angleRight = angle + 90; // Perpendicular to the right
// Create offset points for left and right polygons using the perpendicular angles
MapPoint offsetPointLeft = RotateAndMovePoint(position, angleLeft, offsetDistanceLeft, spatialReference);
MapPoint offsetPointRight = RotateAndMovePoint(position, angleRight, offsetDistanceRight, spatialReference);
// Create polygons based on the direction of the segment
Polygon orientedPolygonLeft = CreateOrientedPolygon(offsetPointLeft, angle, spatialReference);
await CreateFeatureInLayer(layer, orientedPolygonLeft);
Polygon orientedPolygonRight = CreateOrientedPolygon(offsetPointRight, angle, spatialReference);
await CreateFeatureInLayer(layer, orientedPolygonRight);
private MapPoint RotateAndMovePoint(MapPoint point, double angleDegrees, double distance, SpatialReference spatialReference)
double angleRadians = angleDegrees * (Math.PI / 180);
double offsetX = Math.Cos(angleRadians) * distance;
double offsetY = Math.Sin(angleRadians) * distance;
return MapPointBuilder.CreateMapPoint(point.X + offsetX, point.Y + offsetY, spatialReference);
private async Task CreateFeatureInLayer(FeatureLayer layer, Geometry geometry)
var editOperation = new EditOperation
Name = $"Create feature in {layer.Name}"
editOperation.Create(layer, geometry);
var result = await editOperation.ExecuteAsync();
if (!result) // If the result is false, the operation failed
var errorMessage = editOperation.ErrorMessage;
// Log the errorMessage or display it to understand why the operation failed
System.Diagnostics.Debug.WriteLine($"Error creating feature in {layer.Name}: {errorMessage}");
private Polygon CreateOrientedPolygon(MapPoint centerPoint, double angle, SpatialReference spatialReference)
double width = 10; // Width of the rectangle
double height = 5; // Height of the rectangle
double halfWidth = width / 2;
double halfHeight = height / 2;
// Use MapPointBuilder to create points with a spatial reference
MapPoint[] cornerPoints = new MapPoint[]
MapPointBuilder.CreateMapPoint(centerPoint.X - halfWidth, centerPoint.Y - halfHeight, spatialReference),
MapPointBuilder.CreateMapPoint(centerPoint.X + halfWidth, centerPoint.Y - halfHeight, spatialReference),
MapPointBuilder.CreateMapPoint(centerPoint.X + halfWidth, centerPoint.Y + halfHeight, spatialReference),
MapPointBuilder.CreateMapPoint(centerPoint.X - halfWidth, centerPoint.Y + halfHeight, spatialReference)
MapPoint[] rotatedPoints = cornerPoints.Select(point => RotatePoint(point, centerPoint, angle, spatialReference)).ToArray();
Polygon orientedPolygon = new PolygonBuilder(rotatedPoints.Select(p => new Coordinate2D(p.X, p.Y)), spatialReference).ToGeometry();
return orientedPolygon;
private MapPoint RotatePoint(MapPoint point, MapPoint pivot, double angleDegrees, SpatialReference spatialReference)
double cosTheta = Math.Cos(angleRadians);
double sinTheta = Math.Sin(angleRadians);
double translatedX = point.X - pivot.X;
double translatedY = point.Y - pivot.Y;
double rotatedX = translatedX * cosTheta - translatedY * sinTheta;
double rotatedY = translatedX * sinTheta + translatedY * cosTheta;
return MapPointBuilder.CreateMapPoint(rotatedX + pivot.X, rotatedY + pivot.Y, spatialReference);
private async Task DeleteIntersectingTemplates(long featureId, FeatureLayer muffePunktLayer, FeatureLayer muffeArealLayer)
if (!_originalGeometries.TryGetValue(featureId, out var originalGeometry))
return; // If not found, exit the method
var bufferedGeometry = GeometryEngine.Instance.Buffer(originalGeometry, 10);
// Use different spatial queries based on the layer type
await DeleteFeaturesBasedOnLayerType(muffePunktLayer, bufferedGeometry);
await DeleteFeaturesBasedOnLayerType(muffeArealLayer, bufferedGeometry);
private async Task DeleteFeaturesBasedOnLayerType(FeatureLayer layer, Geometry bufferedGeometry)
SpatialQueryFilter spatialQueryFilter = new SpatialQueryFilter
FilterGeometry = bufferedGeometry,
SpatialRelationship = SpatialRelationship.Intersects
List<Geometry> deletedGeometries = new List<Geometry>();
var featureTable = layer.GetTable();
if (featureTable == null) return;
using (var cursor = featureTable.Search(spatialQueryFilter, false))
while (cursor.MoveNext())
var feature = cursor.Current as Feature;
deletedGeometries.Add(feature.GetShape().Clone());
// Create a separate EditOperation for each feature
Name = $"Delete feature in {layer.Name}"
editOperation.Delete(feature);
bool result = await editOperation.ExecuteAsync();
if (!result)
System.Diagnostics.Debug.WriteLine($"Failed to delete intersecting feature in {layer.Name}");
