Hello everyone! It has been so great to see and hear all the enthusiasm around the new GIS Request Management solution. Many of you are up and running and it is so cool to see.
However the #1 question / issue folks are having is adding fields to the request forms. Here is the approach:
1. Add new fields as needed to the GIS_Activities layer.
Do not add domain values - we have seen issues with this
This layer is used for both the GIS Requests and the GIS Activities Survey forms.
2. Open the forms that you want to add the new field(s) in Survey 123 Connect
3. Add the fields to the form manually
4. Add "choices" to the fields for the pick list as appropriate.
5. Publish the survey
6. Update the views - the views do not automically show the new fields - https://doc.arcgis.com/en/arcgis-online/manage-data/set-view-definition.htm
@DanielWickens
