Hi! I'm new with ArcGIS and I'm pretty lost with all about this world. I have been doing a data base on arcmap which it has been published on my arcgis server. Then I created a web appbuilder where I published my map with various widgets but print widget don't work. It says "error, try again" and a note: error executing tool. export web map task job id: j2a26ecf3d5b44a49b0a9c622e33a7328: layer "proyecto": Unable to connect to map server at https://localhost:6443/arcgis/rest/services/PROYECTO/PROYECTO/MapServer
Failed to execute (Export Web Map)
Failed to execute (Export Web Map Task)
I don't have a web adaptor but I don't know if it is the problem (I'm waiting for the licence). Also, I'm wondering who I have to do when I want to show someone the map if we are not in the machine where the server is installed. Because when I want to open the map at home the layers can't be open because it's unable to connect to te server either.
As you can see I don't have any clue about all of this things (I don't have any formation in this kind of thing and I'm learning along the way).
Thanks in advance,
B
