Using the ArcGIS API for Python in a desktop Jupyter notebook. I am trying to automate a process of appending new data from a survey123 feature service into a feature service used by a dashboard. I am trying to use the Append method, but the field mapping does not work for fields that don't have matching names. There are no errors. The append works fine otherwise. Every field that has a matching name in the source and the target data appends and updates with upsert just fine. I seem to have similar or other issues with the Append method in the API for the last three years.
The process I have chosen is to query the records I need from the source data with the result being a dataframe. That dataframe is exported to a GDB. That GDB is used to append the records.
Is this a bug? Am I missing something? Does append just still not work properly?
from arcgis.gis import GIS
gis = GIS("PRO")
sourceData = gis.content.get({itemid})
targetData = gis.content.get({itemid})
targetData_lyr = targetData.layers[0]
sourceData_lyr = sourceData.layers[0]
sourceData_df = sourceData_lyr.query(
where="Contract_Well_Status = 'Plugged' OR Contract_Well_Status = 'In Progress'",
as_df=True,
out_fields="Contract,FARM_NAME,county,Municipality,API,LAT_DEC,LON_DEC,Coal_Area,Bid_Package_to_Construction,Issue_Date,Pre_Bid_Meeting,Bid_Open_Date,Bid_Winner,Contracted_Amount,Recommendation_Memo,Contract_Award_Statement,Actual_Start_Date,Actual_End_Date,Final_Invoice_Amount,Plug_Cert,Final_Inspection_Date,wellStatus,Attainable_Bottom,Solid_Plug,Soil_Remediation,Ecological_Restoration,Infrastructure_Removal,Land_Type,wellScore,Environmental_Impact,Human_Impact,Leaking_Gas,Water_Contamination,environmentalJustice,Contract_Well_Status,Notice_to_Proceed,GlobalID"
sourceData_fc = gis.content.import_data(sourceData_df)
tempGDB = gis.content.search(query="title:" + sourceData_fc.title, item_type="File Geodatabase")
itemGDB = tempGDB[0]
targetData_lyr.append(item_id=itemGDB.id,
upload_format = "filegdb",
field_mappings=[{"name" : "Contract","sourceName" : "Contract"},
{"name" : "Name","sourceName" : "FARM_NAME"},
{"name" : "County","sourceName" : "county"},
{"name" : "Municipality","sourceName" : "Municipality"},
{"name" : "API","sourceName" : "API"},
{"name" : "Lat","sourceName" : "LAT_DEC"},
{"name" : "Long","sourceName" : "LON_DEC"},
{"name" : "Coal_Area","sourceName" : "Coal_Area"},
{"name" : "Bid_Package_to_Construction","sourceName" : "Bid_Package_to_Construction"},
{"name" : "Issue_Date","sourceName" : "Issue_Date"},
{"name" : "Pre_Bid_Meeting","sourceName" : "Pre_Bid_Meeting"},
{"name" : "Bid_Open_Date","sourceName" : "Bid_Open_Date"},
{"name" : "Bid_Winner","sourceName" : "Bid_Winner"},
{"name" : "Contracted_Amount","sourceName" : "Contracted_Amount"},
{"name" : "Recommendation_Memo","sourceName" : "Recommendation_Memo"},
{"name" : "Contract_Award_Statement","sourceName" : "Contract_Award_Statement"},
{"name" : "Actual_Start_Date","sourceName" : "Actual_Start_Date"},
{"name" : "Actual_End_Date","sourceName" : "Actual_End_Date"},
{"name" : "Final_Invoice_Amount","sourceName" : "Final_Invoice_Amount"},
{"name" : "Plug_Cert","sourceName" : "Plug_Cert"},
{"name" : "Final_Inspection_Date","sourceName" : "Final_Inspection_Date"},
{"name" : "Status","sourceName" : "wellStatus"},
{"name" : "Attainable_Bottom","sourceName" : "Attainable_Bottom"},
{"name" : "Solid_Plug","sourceName" : "Solid_Plug"},
{"name" : "Soil_Remediation","sourceName" : "Soil_Remediation"},
{"name" : "Ecological_Restoration","sourceName" : "Ecological_Restoration"},
{"name" : "Infrastructure_Removal","sourceName" : "Infrastructure_Removal"},
{"name" : "Land_Type","sourceName" : "Land_Type"},
{"name" : "AO_Final_Score","sourceName" : "wellScore"},
{"name" : "Environmental_Impact","sourceName" : "Environmental_Impact"},
{"name" : "Human_Impact","sourceName" : "Human_Impact"},
{"name" : "Leaking_Gas","sourceName" : "Leaking_Gas"},
{"name" : "Water_Contamination","sourceName" : "Water_Contamination"},
{"name" : "EJ_Zone","sourceName" : "environmentalJustice"},
{"name" : "Contract_Well_Status","sourceName" : "Contract_Well_Status"},
{"name" : "Notice_to_Proceed","sourceName" : "Notice_to_Proceed"},
{"name" : "GlobalID","sourceName" : "globalid"}
upsert=True,
skip_updates=False,
use_globalids=False,
update_geometry=True,
rollback=False,
skip_inserts=False,
upsert_matching_field="GlobalID")
