I'm working on a Web Map to be used for search and rescue efforts in a watershed region. This map will be shared with dispatch so they can use it in the event of an emergency. We have several posts installed throughout the watershed at certain trail intersections with decimal degrees, and degrees minutes seconds stamped on a plate that is attached to each post. The search option for GPS coordinates works great when entering decimal degrees coordinates but when trying to enter Degrees, minutes, seconds I cant seem to find a way to input the correct format so the map zooms to that location.
Thank you in advance for any help,
Todd
