I am able to connect to a SQL Server database (not a GDB) as either an OLE DB connection or as an SDE connection (using the New Database Connection option in Catalog) - is there an advantage to using one over the other? My use case is mainly extracting a table (approx 250K records) via a python script before applying various manipulations, merging with other data and loading into a GDB.
