I'm wondering if there is a way with Attribute Rules to create a pick list of items when encountering more than one feature while doing an intersects function.
Example: we have leaseholds and condos where our property appraiser draws them on top of each other. I'm doing AR (attribute rules) that use the point where an object is placed to pull certain attributes thru to the point from the parcels layer (and the ones that are stacked). This process works beautifully on single feature parcels. However, due to having the selection be the first of the intersections, then of course, it is only picking the first in the list. I need to change this to where it will show and allow selection of any in the list. I'm thinking that there will be an if, else if that is based on the count for the intersection and then process differently based on if one feature or multiple.
Has anyone encountered this and come up with a solution? I currently have several AR that pull separate pieces of the data into the attributes; however, I am open to using a dictionary, but need help in setting it up. But then, I'm not sure that dictionary is the proper one to use either as it appears that it is more of a 'domain' type item for one attribute, not something that can fill in multiple attributes (fields) in the same row.
Thanks for any insight!
Lorinda
