Hi. I mostly wanted to share a sample application I developed using the Maps SDK and Calcite Components with Angular Material 17.x in case it's of interest or useful to anyone else:
https://github.com/MarshMapper/ngx-arcgis-demo
I'm very impressed with the SDK and the components, and the ability to extend them as needed! I did have one question regarding getting types for the components. You can see, for example, in the arc-map.component.ts file that the way to reference Map, FeatureLayer and other objects is different from importing "whenOnce", for example, in which the braces are used to specify which objects are being imported.
import { CalciteComponentsModule } from '@esri/calcite-components-angular';
import { ProtectedAreasService } from '../../services/protected-areas.service';
import { UnprotectedAreasService } from '../../services/unprotected-areas.service';
import { ProgressService } from '../../services/progress.service';
import Map from "@arcgis/core/Map";
import ImageryTileLayer from '@arcgis/core/layers/ImageryTileLayer';
import FeatureLayer from '@arcgis/core/layers/FeatureLayer';
import View from "@arcgis/core/views/View";
import LayerView from "@arcgis/core/views/layers/LayerView";
import { whenOnce } from '@arcgis/core/core/reactiveUtils';
Is this the best / expected way to import Map, FeatureLayer, etc. to have strong typing for them? It seems to be working well, just want to check if there's a better way to do it.
Thanks for any ideas on this or any other feedback!
