This may not be possible, but I thought I would ask: Can a geometry service be made to work synchronously within a function that returns a value? In other words, in a similar manner that WebMercatorUtil can work? Or can the code in the function be somehow adjusted so as to delay the return of the point until the geometry service has completed and returned the new value?For example, in the following function, 'return newPoint' will complete before the geometry service will fire, because the geometry service call and response is asynchronous (no matter how I do it), whereas one can use WebMercatorUtil synchronously. public function convertToPoint(x:Number, y:Number, bool:Boolean):Point { var _pointObject:MapPoint = new MapPoint(); _pointObject.spatialReference = new SpatialReference(4326); _pointObject.x = x; _pointObject.y = y; if(bool) { _pointObject = WebMercatorUtil.geographicToWebMercator(_pointObject) as MapPoint; } if((bool) && (!isNaN(x)) && (!isNaN(y))) { const projParams:ProjectParameters = new ProjectParameters(); projParams.geometries = [_pointObject ]; var outSR:SpatialReference = new SpatialReference(2277); projParams.outSpatialReference = outSR; this.geomServ.project(projParams, new AsyncResponder( function pResult(item:Object, token:Object = null):void{ var pt:MapPoint = (item as Array)[0] as MapPoint; _pointObject.x = pt.x; _pointObject.y = pt.y; }, function pFault(fault:Fault, token:Object = null):void{ Alert.show("Error: " + fault.faultString, "Error code: " + fault.faultCode); } ) ); } else { _pointObject = WebMercatorUtil.webMercatorToGeographic(_pointObject) as MapPoint; } return new Point(_pointObject.x, _pointObject.y); }Thanks,Jim FaronAustin Independent School District
