hi everyone,
I've created a hosted feature layer with a layer and a table. There is a table relationship between the layer and the table.
I want to create a view of the table. How can I do this with the python api?
I know how to create a view from the layer (index 0), but not from the table (index 1).
here's my code
from arcgis.gis import GIS
gis = GIS("home")
from arcgis.features import FeatureLayerCollection
def search_layer(gis,layer_name):
search_results = gis.content.search(layer_name, item_type="Feature Layer")
proper_index = [i for i, s in enumerate(search_results)
if '"' + layer_name + '"' in str(s)]
found_item = search_results[proper_index[0]]
flc = FeatureLayerCollection.fromitem(found_item)
return flc
def create_view(gis, source_flc, view_name, layer_index, view_def):
new_view = source_flc.manager.create_view(name=view_name)
# Search for newly created View
view_flc = search_layer(gis, view_name)
# The viewDefinitionQuery property appears under layers
view_layer = view_flc.layers[layer_index]
# Update the definition to include the view definition query
view_layer.manager.update_definition(view_def)
search_results = gis.content.search(view_name, item_type="Feature Layer")
item = search_results[0]
item.move(folder='ports')
print("View created")
print(view_layer.manager.properties)
def main():
# Index of the Layer to be filtered
layer_index = 0
source_flc = search_layer(gis, "udi_bfc_secheresse_v2")
# Define a SQL query to filter out events past 1988
view_def_synapse = {"fields": [{"name":"OBJECTID","visible":True},{"name":"UDI_CODE","visible":True,"alias":"Code de l'UDI"},{"name":"UDI_NOM","visible":True,"alias":"Nom de l'UDI"},{"name":"UGE_CODE","visible":False},{"name":"UGE_NOM","visible":False},{"name":"PRPDE_CODE","visible":False},{"name":"PRPDE_NOM","visible":True,"alias":"Nom de la PRPDE"},{"name":"DEP_CODE","visible":False},{"name":"DEP_NOM","visible":False},{"name":"DEP_GESTION_CODE","visible":False},{"name":"DEP_GESTION_NOM","visible":True,"alias":"Département gestionnaire"},{"name":"REG_CODE","visible":False},{"name":"REG_NOM","visible":False},{"name":"BASSIN_CODE","visible":False},{"name":"POP","visible":False},{"name":"ZONE_DEFENSE","visible":False},{"name":"ES_ESMS","visible":False},{"name":"SHAPE__Area","visible":False},{"name":"SHAPE__Length","visible":False},{"name":"GlobalID","visible":True}]}
view_name_synapse = "test_synapse_ok"
if(gis.content.is_service_name_available(service_name= view_name_synapse, service_type = 'featureService')):create_view(gis, source_flc, view_name_synapse, layer_index, view_def_synapse)
view_def_prpde = {"fields": [{"name":"OBJECTID","visible":True},{"name":"UDI_CODE","visible":True,"alias":"Code de l'UDI"},{"name":"UDI_NOM","visible":True,"alias":"Nom de l'UDI"},{"name":"UGE_CODE","visible":False},{"name":"UGE_NOM","visible":False},{"name":"PRPDE_CODE","visible":False},{"name":"PRPDE_NOM","visible":False},{"name":"DEP_CODE","visible":False},{"name":"DEP_NOM","visible":False},{"name":"DEP_GESTION_CODE","visible":False},{"name":"DEP_GESTION_NOM","visible":False},{"name":"REG_CODE","visible":False},{"name":"REG_NOM","visible":False},{"name":"BASSIN_CODE","visible":False},{"name":"POP","visible":False},{"name":"ZONE_DEFENSE","visible":False},{"name":"ES_ESMS","visible":False},{"name":"SHAPE__Area","visible":False},{"name":"SHAPE__Length","visible":False},{"name":"GlobalID","visible":True}]}
view_name_prpde = "test_prpde_ok"
if(gis.content.is_service_name_available(service_name= view_name_prpde, service_type = 'featureService')):create_view(gis, source_flc, view_name_prpde, layer_index, view_def_prpde)
layer_index = 1
source_tbl_flc = search_layer(gis, "udi_bfc_secheresse_v2")
view_def_tbl_synapse = {"fields": [{"name":"objectid","visible":True},{"name":"globalid","visible":True},{"name":"dateSaisie","visible":True,"alias":"Date de saisie"},{"name":"selUDI","visible":True,"alias":"Code de l'UDI"},{"name":"nomDepGest","visible":False},{"name":"nomRegion","visible":False},{"name":"QDeclarationTension","visible":False},{"name":"QimpactQualQuant","visible":False},{"name":"QNonConformiteSecheresse","visible":False},{"name":"parametreRestriction","visible":False},{"name":"moyenGestionComplete","visible":False},{"name":"impactQuantDist","visible":False},{"name":"impactQuantPress","visible":False},{"name":"impactUDI","visible":False},{"name":"communesImpactees","visible":True,"alias":"Communes impactées"},{"name":"observation","visible":False},{"name":"editeur","visible":False},{"name":"pdfCount","visible":False},{"name":"indic_1_3","visible":True,"alias":"1.3 Impact qualitatif"},{"name":"indic_1_4","visible":True,"alias":"1.4 Impact quantitatif"},{"name":"indic_1_5","visible":True,"alias":"1.5 UDI en tension"},{"name":"indic_1_6","visible":True,"alias":"1.6 Mesure(s) non exceptionnelle(s)"},{"name":"indic_1_7","visible":True,"alias":"1.7 Interconnexion exceptionnelle"},{"name":"indic_1_8","visible":True,"alias":"1.8 Transfert d'eau brute"},{"name":"indic_1_9","visible":True,"alias":"1.9 Autorisation exceptionnelle d'un captage"},{"name":"indic_1_10","visible":True,"alias":"1.10 Alimentation par camion citerne"},{"name":"indic_1_11","visible":True,"alias":"1.11 Autre mesure exceptionnelle"},{"name":"indic_1_12","visible":True,"alias":"1.12 Recours à une unité de traitement mobile"},{"name":"indic_1_13","visible":True,"alias":"1.13 Distribution de bouteilles d'eau"},{"name":"indic_1_14","visible":True,"alias":"1.14 Organisation de tours d'eau"},{"name":"indic_1_15","visible":True,"alias":"1.15 Recours aux coupures d'eau durables"},{"name":"indic_1_16","visible":True,"alias":"1.16 Restriction d'usage dûe à la qualité"},{"name":"indic_1_17","visible":True,"alias":"1.17 Paramètre de qualité à l'origine de la restriction"},{"name":"indic_1_18","visible":True,"alias":"1.18 Présence d'ES/ESMS"},{"name":"indic_1_19","visible":True,"alias":"1.19 Commentaire"},{"name":"CreationDate","visible":False},{"name":"Creator","visible":False},{"name":"EditDate","visible":False},{"name":"Editor","visible":False},{"name":"rs_contact","visible":False},{"name":"name_contact","visible":False},{"name":"tel_contact","visible":False},{"name":"mail_contact","visible":False},{"name":"validation_ARS","visible":False}]}
view_name_tbl_synape = "test_tbl_synapse_ok"
if(gis.content.is_service_name_available(service_name= view_name_tbl_synape, service_type = 'featureService')):create_view(gis, source_tbl_flc, view_name_tbl_synape, layer_index, view_def_tbl_synapse)
view_def_tbl_prpde = {"fields": [{"name":"objectid","visible":True},{"name":"globalid","visible":False},{"name":"dateSaisie","visible":True,"alias":"Date de saisie"},{"name":"selUDI","visible":True,"alias":"Code de l'UDI"},{"name":"nomDepGest","visible":False},{"name":"nomRegion","visible":False},{"name":"QDeclarationTension","visible":True,"alias":"UDI en tension"},{"name":"QimpactQualQuant","visible":True,"alias":"Type d'impact"},{"name":"QNonConformiteSecheresse","visible":False},{"name":"parametreRestriction","visible":False},{"name":"moyenGestionComplete","visible":False},{"name":"impactQuantDist","visible":False},{"name":"impactQuantPress","visible":False},{"name":"impactUDI","visible":False},{"name":"communesImpactees","visible":False},{"name":"observation","visible":False},{"name":"editeur","visible":False},{"name":"pdfCount","visible":False},{"name":"indic_1_3","visible":False},{"name":"indic_1_4","visible":False},{"name":"indic_1_5","visible":False},{"name":"indic_1_6","visible":False},{"name":"indic_1_7","visible":False},{"name":"indic_1_8","visible":False},{"name":"indic_1_9","visible":False},{"name":"indic_1_10","visible":False},{"name":"indic_1_11","visible":False},{"name":"indic_1_12","visible":False},{"name":"indic_1_13","visible":False},{"name":"indic_1_14","visible":False},{"name":"indic_1_15","visible":False},{"name":"indic_1_16","visible":False},{"name":"indic_1_17","visible":False},{"name":"indic_1_18","visible":False},{"name":"indic_1_19","visible":False},{"name":"CreationDate","visible":False},{"name":"Creator","visible":False},{"name":"EditDate","visible":False},{"name":"Editor","visible":False},{"name":"rs_contact","visible":False},{"name":"name_contact","visible":False},{"name":"tel_contact","visible":False},{"name":"mail_contact","visible":False},{"name":"validation_ARS","visible":False}]}
view_name_tbl_prpde = "test_tbl_prpde_ok"
if(gis.content.is_service_name_available(service_name= view_name_tbl_prpde, service_type = 'featureService')):create_view(gis, source_tbl_flc, view_name_tbl_prpde, layer_index, view_def_tbl_prpde)
can you tell me what I'm doing wrong?
thanks
