I have been trying to create a data expression for an AGOL dashboard that turns the values from a column ('Year') into their own columns, and then groups by another column ('Type') so that I have the counts for each year for that type.
So, if the original table looks like this:
| Type | Year |
| Apple | 2022 |
| Apple | 2022 |
| Banana | 2023 |
| Pear | 2024 |
I'm trying to create a table that looks like this:
| Type | 2022 | 2023 | 2024 |
| Apple | 2 | 0 | 0 |
| Banana | 0 | 1 | 0 |
| Pear | 0 | 0 | 1 |
I'm not new to scripting but I am new to Arcade, so I've been looking around and piecing together samples to get what I need, and I think I've almost got it. The code below structures the table the way I want it with the columns, but it's not grouping by Type the way I want it to. It's outputting the equivalent of this:
| Apple | 1 | null | null |
| Banana | null | 1 | null |
| Pear | null | null | 1 |
Can anyone let me know where I'm going wrong in my GroupBy expression? Or is there a larger problem with my approach. Thank you!
var p = Portal('url');
var fs = FeatureSetByPortalItem(
p,
'id',
0,
'Original_Year_Field',
'Original_Type_Field'
false
var yearDict = {'fields': [{'name':'Type', 'type':'esriFieldTypeString'},
{'name':'2022', 'type':'esriFieldTypeInteger'},
{'name':'2023', 'type':'esriFieldTypeInteger'},
{'name':'2024', 'type':'esriFieldTypeInteger'}],
'geometryType': '',
'features': []};
for (var feature in fs) {
var cat = feature['Original_Type_Field']
var yearone = Iif(feature['Original_Year_Field'] == 2022,1,null)
var yeartwo = Iif(feature['Original_Year_Field'] == 2023,1,null)
var yearthree = Iif(feature['Original_Year_Field'] == 2024,1,null)
Push(yearDict.features, {"attributes": {"Type": cat,
"2022": yearone,
"2023": yeartwo,
"2024": yearthree}})
var fs_dict = FeatureSet(Text(yearDict));
return fs_dict
return GroupBy(fs_dict, ['Type'],
[{ name: '2022', expression: '2022', statistic: 'COUNT' },
{ name: '2023', expression: '2023', statistic: 'COUNT' },
{ name: '2024', expression: '2024', statistic: 'COUNT' }]);
