Hello all,
Looking for ideas on updating several attributes for about 300k records.
We are using arcgis pro 2.9.5 with utility network and branch version is enabled.
Currently I can add a query table from another database which has the data I need, then do a table join and calculate attribute. Ive done this for batches of around 10k records each time and each batch is taking about 30-60min to run.
While the above will work it is obviously quite time consuming, and as our business is still new to using arcgis we are unsure if there are more efficient methods of doing this.
Any advice or do I just bite the bullet and continue on with the table join method?
Thanks.
