I need to attach either a double-tap/click or a long press to a map that I'm using on a mobile device. Currently double-clicking is not supported on mobile devices. I can include doubleTap.js but it won't attach to a map:var pick = on(map, 'dbltap', function(evt) {
Event.stop(evt);
var latLng = webMercatorUtils.xyToLngLat(evt.mapPoint.x, evt.mapPoint.y);
var location = {};
coords = {
latitude: latLng[1],
longitude: latLng[0],
accuracy:null,
heading:null
var locationInfo = {
coords:coords,
point: evt.mapPoint
pick.remove();
topic.publish('location-picked', locationInfo);
menus.hideTapAndHoldDialog();
Dojo provides a gestures library in DojoX, but it also will not work when trying to attach a listener to a map.on(map, tap.hold, function(e){//does not fire})
The API states a bunch of events that the map object honors, but I need to let a user pan, zoom and then double-click/press and hold to get a point. I've asked a similar question below, but I just need to know if we are completely limited to the events offered.
