This post is similar to that of
Network Analyst Vehicle Routing Problem One Way Streets
I have a road layer with a field called Oneway ('B' - both ways, 'F' - as digitised (From-To), and 'N'- None). I am building road network layer and including restrictions in the travel directions. Therefore, I would like to use the existing script.
ORIGINAL SCRIPT
Streets (From-To): Field -
Prelogic:
restricted = False
Select Case UCase([Oneway])
Case "N", "TF", "T": restricted = True
End Select
Expression: restricted
Streets (To-From): Field -
Prelogic:
restricted = False
Case "N", "FT", "F": restricted = True
End Select
Since, I have only one direction. Could you please confirm the following script is correct:
Prelogic:
restricted = False
Case "N", "F": restricted = False
End Select
Prelogic:
restricted = False
Case "N", "F": restricted = True
End Select
I appreciate your help on this matter. Thank you for your time.
