I would like to build a tool that will load MXD as web map (with reference layers).
I found the MXD to web map GP tool in ArcMap that does exactly this.
Since it is a python script I checked the source and found that its base on ago library.
In github it say that this library is not updated in the last few years but this is still supported tool.
I could write a script that combine ArcMap arcpy (that can publish to server) and python API that can create a web map from map service. Maybe I can write a script that call REST calls to do it.
Anybody have done it or have any advice?
The script should run for a few years until everybody moved to Pro
