Hi, I am using Enterprise v 11.1. I want to use the Chart Widget to create a bar or pie chart using date loaded in as a map image layer rather than a feature layer. When I try to assign the fields for the chart (either by group or by field) I get an error. A little error triangle appears on the chart and says "failed to load". It works if I use a feature layer.
Should the chart widget be able to work with a map image layer?
thanks
Mette
