Hello All,
I was given a seemingly simple task at work to produce a .txt file with a set of data displayed in ascending order of a specific field of a feature class.
I quickly found that I was not able to export a table from Pro to display the data in the order that I wanted. Every time I exported, the resulting table would be in ascending order of the OBJECT ID field, I was never able to export the table in ascending order of the field of my choosing.
I did manage a work around in that I exported the data as a CSV file, opened it in Excel, deleted the column that contained the OBJECT ID field, then saved the file as a .txt file, opened it in Notepad ++, and with my target field now being the first column, I sorted the data in ascending order using the tool in Notepad ++.
I was just curious if anyone has come across the same issue and knows of a way to export a table in ascending order of a field other than the OBJECT ID field, straight from Pro?
Thanks for any insights!
