I am currently testing various equipment for surveying points with an accuracy of < 20 cm. Using Field Maps in combination with Eos and Eos Pro tools works excellently. However, when I attempt to mock the signal using a u-blox device, the results in Field Maps are inconsistent. Sometimes it displays correctly, but not all the time.
My question is: Is there a way to mock signals consistently across different manufacturers?
Thank you for any insights or suggestions you can provide!
