started with ArcGIS API for JS only today and am having issues loading scenes from a public portal already. If I use an ID from a public AGOL portal item, my scene shows as intended. If I change to an on-premises portal url with esriConfi.portalURL, nothing appears at all.
<script>
require([
"esri/config"
"esri/WebScene",
"esri/views/SceneView"
], function(esriConfig, WebScene, SceneView) {
// Set the hostname to the on-premises portal
esriConfig.portalUrl = "https://arcgisportal.mysynergis.com/portal/";
var webscene = new WebScene({
portalItem: {
var view = new SceneView({
container: "viewDiv",
map: webscene
</script>
Any idea what's missing? Also what platform would you suggest for debugging? The ArcGIS API for JavaScript Sandbox doesn't show anything... (also is here on the community forum a proper way to post code like on stackoverflow?)
Thanks!
