I have a map where the source for a layer was moved via Windows Explorer. The folder where the data is located WILL NOT show up, no matter what / where / how many times I refresh. I've tried everything suggested in the ESRI help.
Not only can I NOT repair the data source, I can't even remove the layer and re-add it, because, you guessed it, Pro refuses to see it.
Somewhat ironically, the aprx is also locatred in this folder (the data is in a subfolder) - so the aprx isn't even seeing the folder that itself is located in!
The data needs to stay in this new location. Its name does not include any special characters, etc.
If I can't refresh the folder, database, etc via catalog view / catalog pane, and I can't re-add the layer in it's new location, how can I use my data? Why does Pro insist that this folder doesn't exist???
