Hi all,
I've written a script in which I analyze the TOC content in a selected map document. The analysis produces a list of datasets (table, shapefile, geodatabase fc, raster, mosaic dataset, etc...) in the TOC. If a dataset has missing datasource the information will be also reported.
Python code:
import arcpy
mxd = arcpy.mapping.MapDocument(mxdFilePath)
dtfs = arcpy.mapping.ListDataFrames(mxd)
for dtf in dtfs:
for dts in arcpy.mapping.ListLayers(mxd, "", dtf):
if dts.supports("DATASOURCE"):
if not arcpy.Exists(dts.dataSource):
file.write("\t Missing datasource! \n")
else:
# do something.............
So I've created a Toolbox (tbx), added the script e run it: everything works well.
I've also embedded that script in a Python Toolbox (pyt) and run it: everything works well but Personal Geodatabase feature classes return always a "missing datasource" message, althought the data exist and datasources are correctly set.
Finally, If I run the pyt script as shown here, again everything works well.
So, I do something wrong in my Python Toolbox..... but what? Any help please?
Using Python 2.7.2 and ArcGIS 10.1.
Thanks in advance
