I am new to ArcGIS JavaScript API and trying to migrate from 3.X to 4.X. Have some problems with the print service in 4.X.
Try to add a MapImageLayer (esri/layers/MapImageLayer) into a Map (esri/Map) object then print into an image with this print API https://developers.arcgis.com/javascript/latest/api-reference/esri-rest-print.html . However I always got blank output image file without any http errors. However, if I create the Map object with basemap like:
new Map({basemap: "topo-vector"});
then it can print something out. I tried the following code with the ArcGIS online sample website (https://developers.arcgis.com/javascript/latest/sample-code/sandbox/?sample=widgets-print) which uses print widget and got same blank output.
Is there anything wrong with the code or miss anything? Any suggestions would be great.
Thanks a lot.
#########################Online testing code#########################
<html lang="en">
<head>
<meta charset="utf-8" />
<meta name="viewport" content="initial-scale=1, maximum-scale=1,user-scalable=no" />
<title>Print widget | Sample | ArcGIS Maps SDK for JavaScript 4.29</title>
<link rel="stylesheet" href="https://js.arcgis.com/4.29/esri/themes/light/main.css" />
<style>
html,
body,
#viewDiv {
padding: 0;
margin: 0;
height: 100%;
width: 100%;
overflow: hidden;
</style>
<script src="https://js.arcgis.com/4.28/"></script>
<script>
require(["esri/views/MapView", "esri/widgets/Print", "esri/WebMap", "esri/Map", "esri/rest/support/PrintParameters", "esri/rest/support/PrintTemplate","esri/layers/MapImageLayer", "esri/rest/support/ImageParameters"], (MapView, Print, WebMap, Map, PrintParameters, PrintTemplate, MapImageLayer,ImageParameters) => {
var map = new Map();
var imageParameters = new ImageParameters();
imageParameters.layerIds = [];
imageParameters.layerIds.push(0);
imageParameters.layerOption = ImageParameters.LAYER_OPTION_SHOW;
imageParameters.transparent = true;
var url = "https://services.arcgisonline.com/ArcGIS/rest/services/World_Topo_Map/MapServer";
var layer = new MapImageLayer({ url: url, customParameters: imageParameters });
map.add(layer);
const view = new MapView({
container: "viewDiv",
map: map
view.when(() => {
const print = new Print({
view: view,
// specify your own print service
printServiceUrl:
"https://utility.arcgisonline.com/arcgis/rest/services/Utilities/PrintingTools/GPServer/Export%20Web%20Map%20Task"
// Add widget to the top right corner of the view
view.ui.add(print, "top-right");
</script>
</head>
<body class="calcite">
<div id="viewDiv"></div>
</body>
</html>
