When I look at my existing fields, I have a couple with the type as "Small Integer"
However when I try to add a new field it does not give me the option for a "Small Integer". I see "Big Integer" and regular "Integer"
I can work around this by making the changes locally and republishing, but I am hoping that there is a simpler way to do it directly online.
NOTE: the solution says to drill down into the layer before clicking on Admin. I had to do it the other way around because Admin would disappear when I had clicked on the layer name. But it did work in the end!
