I created a preset template (line with a junction at the beginning and end) but it does not appear in the Copy Parallel tool as a template option. This tool is extremely useful in our workflow. It would save time if we could use the preset template to copy junctions while also copying the lines at the same time.
The preset template exists in the Line template section when I check Manage Template and Create Features. I am able to manually create features using this template. It just isn't showing up in the Copy Parallel tool.
Is this possible or is there a limitation of the Copy Parallel tool? If there is a tool limitation, is there a work around?
