Hi, I have a survey created in connect with a set of questions in a repeat and a repeat count set to 3. I have my first question setup as an autocomplete search on a hosted feature layer in my organization. There are only 9 options to choose from and that loads and operates fine. Based on this selection, the next question, also a select_one, is filtered to relevant choices also using autocomplete search on a hosted feature layer. The issue I'm having is that the list will load, with only the "a through c" options visible, and as I try to type a name that is not listed, it will come up briefly in the dropdown list, but then the list disappears before I can select it. This is very frustrating and definitely not user friendly for the users of this survey. Is there a paramater somewhere I need to configure for a list of thousands of choices pulling from a hosted feature layer? Thanks for any info.
