(ArcGIS Pro 3.2.2, Advanced license through campus)
Hi:
I have tried several times to figure out what is going on, but I am really baffled! I have feature layers that may be updated only very occasionally, so adding a new record by hand is not too onerous (and to preserve symbology). The attribute tables allow edits, both add new field and add new record. But when I enter data into the new record and save edits, the feature layer doesn't update to the map. I've tried the refresh button, saving the project, close, re-open...and a few other things I read online and in these forums.
From all this, I think the problem is that the data is not recognized as coordinates, as when I tried "Repair Geometry" with the default "delete null", the new record was deleted.
I also tried exporting the single record from within the attribute table to a standalone table, then xy table to point tool. Again the new feature layer was empty.
Any ideas on what is going on here? From what I have read, editing an attribute table should be a legit way to add data to a feature layer/map.
Thank You!
Vicki
