I'm trying to make a custom build using the 4.10 JS API, but I keep getting a build error:
18 verbose node v10.15.1 19 verbose npm v6.9.0 20 error code ELIFECYCLE 21 error errno 3 22 error arcgis-js-api-sample-app@1.0.0 build: `grunt build` 22 error Exit status 3 23 error Failed at the arcgis-js-api-sample-app@1.0.0 build script. 23 error This is probably not a problem with npm. There is likely additional logging output above.
Before in the 'npm install' I had this error:
verbose stack Error: node-sass@4.7.2 postinstall: `node scripts/build.js`
So, I changed the "node-sass" version by "node-sass": "~4.9.0" in the package.json file.
I'm using the one recommended in the 4.x JS API Bower section guide from here: Using npm for Custom Builds
