I am trying to do some conditional calculating. I have an address field in my survey and I'm using pulldata @layer to get the address of a parcel that the point is placed on.
If the point is not placed on a parcel, I'd like to return a piece of text like "No Address Found" or something.
My actual pulldata is working fine, I get addresses when the point is on a parcel, but I want to set a default value. From what I understand, actually using Default might not work because that only evaluates when the survey is opened, so if I click a point that isn't on an address, then the default is overwritten with nothing.
pulldata("@layer", "getValueAt", "attributes.ADDRESS", "<parcel REST endpoint>", ${EP311_point})
