Hi,Has anyone been able to display a WMTS service in OpenLayers? I have been trying for several days without success.OpenLayers 2.12ArcGIS Server 10.1Capabilities:http://geoappext.nrcan.gc.ca/arcgis/rest/services/BaseMaps/CBCT3978/MapServer/WMTS?Here is some of the code I have tried:
<!-- OpenLayers Start -->
<script type="text/javascript" src="js/proj4js-compressed.js"></script>
<script type="text/javascript" src="js/OpenLayers.js"></script>
<script type="text/javascript">
// Add projection
Proj4js.defs["EPSG:3978"] = "+proj=lcc +lat_1=49 +lat_2=77 +lat_0=49 +lon_0=-95 +x_0=0 +y_0=0 +ellps=GRS80 +datum=NAD83 +units=m +no_defs";
var options2 = {
div: "geomap2",
theme: null,
controls: [
new OpenLayers.Control.Attribution(),
new OpenLayers.Control.TouchNavigation({
dragPanOptions: {
enableKinetic: true
maxExtent: new OpenLayers.Bounds(4926564.35035694, -5396818.737236813, 5347435.64964306, 4659495.9082),
maxResolution: "auto",
projection: "EPSG:3978",
restrictedExtent: new OpenLayers.Bounds(4926564.35035694, -5396818.737236813, 5347435.64964306, 4659495.9082),
units: 'm',
displayProjection: new OpenLayers.Projection("EPSG:4269"),
numZoomLevels: 18
// map2 is the map used to define an extent using the map (option c)
map2 = new OpenLayers.Map("geomap2", options2);
var styleBBOX = new OpenLayers.Style({
'fillOpacity':0.05,
'fillColor':'#008000',
'strokeColor':'#008000',
'strokeWidth':1
bboxLayer2 = new OpenLayers.Layer.Vector("BBOX_Overlay2",{styleMap: styleBBOX});
var pzb2 = new OpenLayers.Control.PanZoomBar({'div':OpenLayers.Util.getElement('panzoombar2'), zoomStopHeight: 8})
pzb2.position=new OpenLayers.Pixel(210,0);
currentLayer2 = "lowContrast";
// If tile matrix identifiers differ from zoom levels (0, 1, 2, ...)
// then they must be explicitly provided.
var matrixIds = new Array(18);
for (var i=0; i<18; ++i) {
matrixIds = "EPSG:3978:" + i;
var wmts = new OpenLayers.Layer.WMTS({
url: "BaseMaps_CBCT3978",
layer: "BaseMaps_CBCT3978",
singleTile: false,
//matrixSet: "CBCT3978",default028mm
matrixSet: "default028mm",
matrixIds: matrixIds,
format: "image/jpg",
// //requestEncoding: "REST",
requestEncoding: "KVP",
style: "default",
opacity: 0.7,
isBaseLayer: true
map2.addLayer(wmts);
This generates URLs of the form:
http://dev.geogratis.gc.ca/demo_wet3/BaseMaps_CBCT3978?SERVICE=WMTS&REQUEST=GetTile&VERSION=1.0.0&LAYER=BaseMaps_CBCT3978&STYLE=default&TILEMATRIXSET=default028mm&TILEMATRIX=EPSG:3978:0&TILEROW=1&TILECOL=0&FORMAT=image/jpg
and those URLs give me 404 errors.Can anyone spot the problem?Thanks,Paul
