Hello -
I am seeking documentation on the required structrure of a CSV when using the Add Data Widget - Upload Files function.
I am using ArcGIS Enterprise 11.2.
The ESRI Add Data widget documentation does not outline what the CSV structure should look like: https://doc.arcgis.com/en/experience-builder/11.2/configure-widgets/add-data-widget.htm
My testing so far indicates, that having the following field names in a CSV will upload and display on the map successfully:
lon, lat
longitude, latitude
^ in both instances this works with underlying decimal degree values under the field names.
Is anyone aware of documentation on the specifics of compatible strucutures.
Can easting, northings be added? Can coordinates be added that don't meet the map coordinate system (mostly web mercator)?
Any thoughts appreciated.
