I am creating a Microsoft Power Automate Flow to take my Survey123 submissions and create new line items in my Microsoft List.
In this specific Survey123, I have a field for replicate number, which if the answer is >1, will require a repeated replicate name field. The number of repeats of the replicate name field corresponds to the numeric value entered in the replicate number field.
As it stands in my flow, the number of line items created is related to the number of replicates. All is running smoothly except, when I try to submit a survey response with only one replicate, the flow fails.
I know that this has something to do with the "Select an output from the previous step" section in the apply to each section of the flow. However, if I change this dynamic content from the repeat replicate names field, the flow continues to fail for single replicates, or will not import replicate names for more than 2 replicates.
How do I resolve my issue to have the correct number of line items for the number of replicates with the names imported and be able to have the flow run with only one replicate too?
Below are screen shots of my flow as well as the failed error.
