I'm trying to publish a survey from Survey123 connect and the publishing process hangs (4 hours now).
All I see is the green circle spinning.
I've isolated this to the media folder, which has about 117 mb of files in it. If I remove all the files the survey publishes fine. I'm currently trying to see if there is a #files or size of folder cutoff that causes it to hang, but curious if anyone knows if there are specific limitations here.
Thanks!
