Before installing ArcGIS Pro, I had an anaconda installation on my machine. Every time I open the command prompt and try to open a conda environment to use ArcPy, it does not activate conda in the ArcGIS directory.
How can I set up my machine so when I type "conda" in the command prompt I am using the ArcGIS Pro install so I can easily run stand-alone python scripts with ArcGIS?
