I have a ployline shapefile that I need to split by road class attributes in the table but need to retain all the original data after the split or extraction by arterial, collector, local roads, etc. I've tried to select by attribute and extract or use the extraction tool but the output is one large line and all the attributes are gone. Which would be the best way to retain all the original data, I just want to pull out all arterial roads from the file. I was thinking of editing the attribute table to delete all lines that are not arterial or try the splitting tool but not sure which process would be best. Any help or guidance would be greatly appreciated. Thanks, Patrick
