I am curious if/when other users are implementing "non-nullable" fields in their feature class/table design? If so, why? What does it achieve/what are you trying to achieve? I ask because I don't understand the utility of this setting.
If I have a TEXT field that is "non-nullable", ArcGIS Pro will just throw in an empty string (maybe a space " ", my point is the same) as I am digitizing features. If I have a non-nullable numeric field, ArcGIS Pro will populate it with a "0". Date field, 12/31/1899. So, while the field is technically "non-nullable", this doesn't really help me from a data-integrity standpoint. If Pro would throw an error during editing that would prevent saving a record (similar to an Attribute Rule that fails, or a correct domain value not being chosen), I would understand the purpose. But it doesn't throw an error--it just fills in a generic value. The worst offenders are numeric fields, where Pro will populate a "0", which to me, is much harder to detect as an issue than simply allowing a <NULL> in that field, indicating the record should be reviewed. At least 12/31/1899 stands out as being a weird value that might require further review.
Is the point simply to prevent NULL values because... they are not acceptable in a particular database for some reason (why not? why is "" and "0" filler data better?)? Does the nullability setting result in a different experience for FieldMaps users, where it actually makes more sense?
For whatever it's worth, I am speaking mostly of File Geodatabases here, but do work regularly in Enterprise Geodatabases (SQL Server). If the behavior is different or makes more sense in an EGDB, I would be happy to hear about that too.
Thanks, genuinely curious how folks are using the "nullability" setting.
