Good Afternoon,
I've been doing some testing with the new Oriented Imagery capabilities in AGOL, but I have only managed to upload one test set of data properly. My last couple of attempts have ended up with maps where the OI field-of-view cone points in the opposite direction of the actual view of the photo (pictured below). If this is working as intended, I wonder if some sort of offset can be added to the dataset to better pair the aerial and 360 imagery.
Is there a best practice for adding images to the OIC dataset? I've attempted using a .txt file with the image paths and making a feature layer that follows the OIC table schema. My one successful Oriented Imagery Viewer map was created using the .txt method, but that test was also with a much smaller dataset.
Any information would be a great help and thanks in advance!
